Discuss Identifying waste pipe type in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
How can you tell if a white 30 or 40mm waste pipe is pvc or abs?
Floplast solvent weld glue seems to work on both of these in as much as it’s the only glue I use and I’ve never had a problem.
Admittedly I am only talking about waste pipe runs and not pressurised water supplies , but if you are using it for waste pipes you will be fine.
Reply to Identifying waste pipe type in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
