Discuss Immersion heater is working but no hot water coming through taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Lai
Please can someone help. Plumber came to property and said that the immersion heater is working. We do not have any hot water coming through the taps. He said that he is unable to locate a thermostatic mixing valve in the property which needs to be repaired. Where is this located?
Please find image attached of cylinder
[automerge]1565628047[/automerge]
Isolate mains cold water and then see if you have hot come through.
My guess would be a mixer shower somewhere. What showers do you have? Also what taps?
Reply to Immersion heater is working but no hot water coming through taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
I have read of hot water cylinders being heated with a dual element immersion heater. The main principle being that a shorter element heats the...
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
