Discuss ideal logic 30 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gasmansam
Hi guys, I changed a pcb on an ideal logic 30 as it was stuck on l2 fault, after testing and getting no power at gas valve. I got it all going fine, apart from on hw. When you run the tap nothing registers on the boiler, I took the turnine out and checked it was moving freely, but im not really familiar with this style of the hw side. Is there anything I could of done whilst changing the PCB or is it just going to be the clip in microswitch that sits on top of the turbine? I have checked all the connections on the pcb are clean and ok.
Thanks in advance
Please read the forum rules regarding gas and boilers.
Build your post count up to 10+ then send a message to [email protected] with a picture of your gsr card on and tell us who you are on here.
Reply to ideal logic 30 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
PSxxxxxx
Sonya K
