Discuss ideal logic 30 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gasmansam
Hi guys, I changed a pcb on an ideal logic 30 as it was stuck on l2 fault, after testing and getting no power at gas valve. I got it all going fine, apart from on hw. When you run the tap nothing registers on the boiler, I took the turnine out and checked it was moving freely, but im not really familiar with this style of the hw side. Is there anything I could of done whilst changing the PCB or is it just going to be the clip in microswitch that sits on top of the turbine? I have checked all the connections on the pcb are clean and ok.
Thanks in advance
Please read the forum rules regarding gas and boilers.
Build your post count up to 10+ then send a message to [email protected] with a picture of your gsr card on and tell us who you are on here.
Reply to ideal logic 30 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
1K
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that time the boiler was fine. Today the boiler has lost pressure. I have followed the videos on yt and nothing works. Just stays telling me F1. I have...
FrankMcg
F
J
Turned the system from hot water only, to hot water and central heating the other day. After it working briefly, it has now stopped all together. The display isnt showing a fault or anything - it is just blank. After reading the service guide that came with it - I am confident there is power...
James Middleton
J
E
Have an Ideal Logic + 18 with intermittent fault. When on demand the display constantly changes from O to C but burner doesn’t start. Can fix by switching Off then On again, but this only lasts for a day or two. As it’s an intermittent fault I’m reluctant to call out an Engineer. Any ideas?
Hi all. Have a problem with ideal combi. Working perfectly ok on heating then stopped with the L2 code. Firstly tried resetting,checked condense and flue, all ok. Gas valve is opening ok but with no ignition. Embarrassingly I’m not too familiar using a multimeter (even tho I have one !) so...
