CP12 & service needed for an empty property to let it out. Boiler is an Ariston Microcombi 23. Gas pipe runs 14-15 meters and all the way in 15mm so clearly undersized. Working pressur at the meter is 22mbar, inlet pressure is 10mbar. Should this be classed as AR? Appliance disconnected at the moment. Also the boiler is not fixed to the wall properly, it has been fixed using a pad onto the wall, the pad is hanging off the wall at the top by about 25mm
