Discuss How to control pump in multi boiler system in the USA area at PlumbersForums.net
Hi all, hopefully you are good,
The system I am looking at has an oil boiler, a solid fuel boiler, triple coil cylinder, 2 space heating zones and a 'systemlink' ,
Would anyone out there know which controller / wiring centre is recommended for these system links?
Also, and more importantly, while I understand the control logic for most of the system, could anyone advise how the space heating pump is controlled as it needs to be called on by the solid fuel stove after the solid fuel DHW demand is satisfied as well as being available to be called on by the main controller when the oil boiler needs it?
Thank you and best regards,
S.C.
Reply to How to control pump in multi boiler system in the USA area at PlumbersForums.net
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended...
I have recently moved into a house with a central heating system that runs from oil or/and the multi fuel stove. The water gets hot and then...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
