Discuss Honeywell motorised valve not working correctly? in the Central Heating Forum area at PlumbersForums.net
Thanks, that's what I thought might happen alright, so obviously cannot stay in mid position except calls for both HW&CH, still, a very ingenious design, it also has another resistor to give a AC de magnetizing current.
H/w is default position. If Last call was central heating valve stays until next call depending on cylinder stat satisfied and its hot water priority..
Reply to Honeywell motorised valve not working correctly? in the Central Heating Forum area at PlumbersForums.net
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
I have tried hard to get similar to the first class satchwqell /Sunvic SML type revolving type valves instead of the quite short lived spring...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
