  • Thread starter Lee John
  • Start date
  • Replies 4
  • Views 2K
Discuss hey in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lee John
Hey I'm new here, looking for some advice I need a small overflow connector to fit a 17mm dia hole, any specific size I need? Has to be plastic since its being used on glass
Is this for a fish tank?
What size pipe are you planning to connect to it?
yes it is I am planning to connect them all up to 1" eventually just need a fitting for the 17mm hole, its a drip system for barracks I know the rest just need a connector size, cheers
You'd be best off going to an aquarium supplies place for that sort of size in plastic.
Reply to hey in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
