Discuss Help: What is an automatic water valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumber4life
I am fresh outta college, recently qualified and being wet behind the ears some things are new to me. So can any of you experienced guys please explain to me what a automatic water valve is and whats its function? :confused:Cheers
next time you go for a pi** in mcdonalds - look upwards, and you should have the answer. you might want to pop into city plumbing and ask them for a long weight as well, they can be really useful. Dont forget to order some bubbles for your level in case you drop it. Most important is to always look out for spur lashings when its raining, keep some in the van.
next time you go for a **** in mcdonalds - look upwards, and you should have the answer. you might want to pop into city plumbing and ask them for a long weight as well, they can be really useful. Dont forget to order some bubbles for your level in case you drop it. Most important is to always look out for spur lashings when its raining, keep some in the van.
Don't forget the tartan paint old plumber!
i get the feeling someone might have his boots screwed to the floor next to that really heavy toolbox u cannt lift suddenly lol
Are you sure? I thought a "spur lash" was the knot for tying anchors on with.
Plumb4life Its a bit of a broad question and there are many that may come under "automatic valve" like you i know very little about them other than fitted up steam of a pet cock feeding an auto flushing cistern they reduce waste water. (recognise pressure flutulation in a building) When the staff go home the cistern wont fill. And infra sensing for posh basin taps etc.
and when u pee in macdonalds look up and ull see one in action, and then you might get wet hands and feet
Naughty! You weren't supposed to use references!
Naughty! You weren't supposed to use references! :D
Reply to Help: What is an automatic water valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi, I'm Dave, New to the site and have a question I was wondering someone may be able to advise me with. I have recently moved into a bungalow...
2K
  • Locked
Hi all, I'm new to the forums and relatively new to plumbing, and wondered if any of you experienced chaps could help me out... I went to...
2K
danwildman
G
  • Locked
Moved house a while ago and had a few issues with the plumbing. Taps dripped, pipes rattled when cold water switched on, washing machine leaked...
Sharp Point
J
  • Locked
hello new member qualified last june city and guilds 3yrs lacking tools experience. i recently changed a old toilet flush for a new turbo flush...
2K
C
  • Locked
Hi, please can someone help? I had a new Fluidmaster concealed cistern bottom entry fitted recently. Model is Fluidmaster 400UK bottom inlet...
4K
PlumbBobBob
