Discuss Help diagnose Ariston boiler fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I have a boiler engineer coming out, but it's not till next week, so I was just curious if anyone knew what this fault could be in case it was something obvious, it's the first I've tried heating since May...
Ariston Clas HE EVO38
No error messages, hot water is fine, but no heat. Even after putting the RF unit in override (however it is syncing ok and I can see the connection triggering to turn the relay on when I ask it), the boiler doesn't trigger.
However, if I hold the reset button and perform a 10 minute maximum heat test it works just fine. Pressure is 1.5bar and goes up over 2bar when it turns on as it's always been.
Any ideas?
Thanks.
I’m guessing not a Combi Boiler if so is the port valve moving / opening ?
Link the live and switched live on the control stat wiring receiver. See if that fires it up. If so stat fault. If not then it's a boiler fault. Combi would needed opened up and looked at, need an engineer for that.
Ok, I opened the comb and bypassed the thermostat. Just as Duncan said, thanks ;)
So, question is, this is a siemens rdj10f with a siemens rcr10 unit. What's the best way to determine which is at fault? I did press the 'override' button on the rcr10 unit and the relay light came on but no heat. Is it worth wiring the unit back in and moving the jumper to the rcr10 unit to see if that is the fault?
Thanks.
How's it a boiler fault? I disconnected the thermostat and put the jumper back on the boiler and it works fine, so isn't that simply the the thermostat at fault because it's just a N/O switch isn't it?
Thanks.
Reply to Help diagnose Ariston boiler fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am currently having issues with an Ariston Combi A series boiler giving an E08 - "No water in primary circuit" error code, the circuit is...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
