Discuss heat input in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jambo
can some advise me on the best way or formula to do a heat input calculation
heat input in kW is the c v of
fuel times the fuel flow rate.viper book in van and can't be bothered going out
i tend to measure the time it takes to do one full revolution if an imperial meter, or measure the difference between readings over 2 minutes on a metric meter then refer to the corgi hand book.
Reply to heat input in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, i'm doing some heatloss calculations, going by a fairly old plumbing book. The formula for calculating heatloss would be Surface Area x...
I was looking into a problem with flow rate in my bathroom. A bit confused with how flow rate, water pressure, pipe length, and difference in...
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
Hi apologies of this has been asked before but when you gas rate an appliance and trying to compare to the technical data, do you go off the...
Deleted member 120897
