Discuss Heat exchanger problem in the USA area at PlumbersForums.net
Atanas Peev
Hello everyone do any one had such experience with main heat exchanger on combi boiler
Thank you
Yep through the core plug new boiler
Could be just a bad core plug have seen it happen around winter time when the house has been empty eg no heating on and it’s partially frozen
Reply to Heat exchanger problem in the USA area at PlumbersForums.net
E
We just had a service done on our Ideal ICOS boiler and were told that the 2 screws on the back of the heat exchanger have snapped off. It was...
Hi everyone, I have taken out the heat exchanger because a tiny leak was found around the red gasket at the top of the heat exchanger of a...
Hi, Boiler is losing pressure, from 1.5 bar to 0 bar in about 4 hours. Have checked all rads and seem to be fine, no water out external prv...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate...
