Discuss Hate worcesters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I did think flow switch but couldn't understand why it would initial fire up
Could be sensing flow and then no flow etc
Won't let me. Trying to do it all on phone but it's having none of it
Sure its trying to re-light and its not the pump pulsing? It does that when it overheats from a blockage in the plate.
Well from the video of it she sent me it never actually locks out so that could well be reasonable
Riley, (knowing that you have said that the heat side is ok) I am still going to go with...low gas pressure as the sequence you describe is about right, burner fails and tries again (5 times?) saying that flame rectification is almost the same or just ignore this as I am only trying to bump my posts up!
The pump pulses like every 10 seconds or something. Ignition failure would lock out after 3-5 attempts and would need resetting. Tell her to leave the heating off until the flow and return go cold. Then run the hot water and see if its dumping down the flow. If it is then its nearly always the plate. Diverter motor would also be worth a check though.
No lock out? I think you have a blocked plate. I had this last week. I replaced the plate and it runs on hot water like a dream
Reply to Hate worcesters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone a local installer has recently quoted me £3,660 for a complete install using the main eco compact 25kw boiler i have also been...
2K
Deleted member 131795
I need a little help if possible as I am trying to check that my current system is running efficiently but not really sure how to check, sorry if...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
H
HRP123
H
Hi All, I have a Firebird Enviromax external oil boiler, it has a Riello RDB2.2 C26 burner which keeps locking out. It has been an ongoing...
5K
schubes18
