Discuss Grant Vortex Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
A FLINT
Hi I have a grant vortex oil boiler and I have turned it off for 4 days. When I turned it back on I can't get any hot water or heating. I have filled water pressure back up but light at bottom of boiler isn't on could this be the problem if so how do I sort it?
Well there's your problem, its a Grant :)
Seriously though, find a competent engineer to take a look.
If youve had to fill it up with water the chances are its overheated. Undo the plastic nipple on the front panel marked overheat or limit stat and press the button underneath, if it clicks it has been triggered and the boiler will go
Reply to Grant Vortex Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
