Discuss Grant Vortex Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
A FLINT
Hi I have a grant vortex oil boiler and I have turned it off for 4 days. When I turned it back on I can't get any hot water or heating. I have filled water pressure back up but light at bottom of boiler isn't on could this be the problem if so how do I sort it?
Well there's your problem, its a Grant :)
Seriously though, find a competent engineer to take a look.
If youve had to fill it up with water the chances are its overheated. Undo the plastic nipple on the front panel marked overheat or limit stat and press the button underneath, if it clicks it has been triggered and the boiler will go
Reply to Grant Vortex Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Grant Vortex 50/90 condensing oil boiler where the air tube spigot over the fan is not connected to the existing flue, should this be closed off with a Reillo cover plate to stop vermin getting into the open fan motor.If is blanked over will need a further combustion test to confirm adequate...
I have a Grant Vortex Blue 26kw external oil boiler, installed less than 12 months ago. It's had intermittent non-starting problems resulting in multiple warranty visits, part replacements and eventually burner replacement. The replaced burner I discovered was a 'yellow flame' one, apparently...
A
My oil boiler is 2009 vintage. Just been serviced. Had a new tank fitted by approved fitter. I notice that the bottom of the tank is roughly on the level of the boiler feed pipe. Then I notice in the Grant instal manual for a single pipe feed the tank should be 300mm min above the boiler feed...
We've had a Grant Thornton oil boiler for about 5 years and suddenly it trips the electricity when it rains? The unit is in a wood shed and the exhaust goes out the wall horizontally. I can't see any water ingress in the machine, so at a real loss......and very cold..!!!!
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
