Discuss Glow worm Flexicom 30cx brief cutout in the Central Heating Forum area at PlumbersForums.net
Hi all, got the above boiler that was installed in the house back in 2009 before we moved in in 2017.
The boiler works as it should, it heats up the hot water and the radiators fine and everything is balanced. however it has started to act rather strange with the heating on.
The boiler will heat the house up but it will randomly cut out for around 3 seconds. The pressure will drop from 2.1 bar to around 1.7. Then it will fire back up and will then display the current CH water temperate of about 55.c and then show it increasing back up to the 77.c I set it to. Then it will run fine again for awhile and do it again, repeating the process until the Nest thermostat has reached the correct temperature and turn the heating off. When the boiler cuts out it has nothing to do with the Nest thermostat, more to do with the boiler itself. However I’m not too sure where to start? I understand the age of the boiler and it probably would be best to replace it, but we’re planning a huge kitchen renovation and extension so it’s not the time to be changing it.
Thanks all in advance,
2 key points to make, I have a magnaclean filter attached which I clean every 6 months or so, recently cleaned it and it’s not bad, nothing abnormal.
I have noticed that the display will show the CH water temperature 2 degrees higher than what it is set to, I have turned it up to maximum a few times to see if it makes a difference and it just seems like it’s lessens the frequency of the cut out occurring.
Read more: Gloworm flexicom 30cx cutting out briefly. - https://www.diynot.com/diy/threads/gloworm-flexicom-30cx-cutting-out-briefly.566318/#ixzz6oejLCSaE
Reply to Glow worm Flexicom 30cx brief cutout in the Central Heating Forum area at PlumbersForums.net
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi Have a Glow worm Flexicom 30cx-Installed 2010 and regaularly serviced. Last service October 21. Works fine, with no issues. However it has...
I got a problem with my boiler,it's got some vibration when it starts to work,it doesn't fire up unless I duck tap and blank half of the air...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
