Discuss float valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
buckley plumb
anyone know the make of this float fill valve and how to separate it on the height adj as need to replace it - tried the washer and no joy - I would normally fit a fluidmaster but the toilet is a back to the wall pan an has been tiled around pan and no nailed to the floor.
I'm not sure on this one, have you replaced washer? Sounds like a pain
If it does separate, you would normally turn it 1/4 turn then pull up if it is height adjustable
Usually when I see plastic cistern to pan bolts & that turquoise colour it means the works are Chinese, or from that region, so you might have trouble.
Do you know what make the loo is?
Looks like a fluid master head? Screw off and replace leave stalk in place?
managed to get the head off but the washer is not a fluidmaster or like anything I have seen. twisted the body to adjust the height and I slides up put wont pull out like other makes must have a stop lip on it . looks like I am going to have to try in free the pan from h tiles around it. why do people tile around pans
Reply to float valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low...
I have moved into a property and amongst several other issues, the toilet float valve appears to keep getting stuck and therefore prevented from...
Deleted member 120897
Hi, one of the two hooks on my toilet Torbeck fill valve has broken, and so the float can't connect. I've bought a new fill valve, however it's...
Had a issue with a Fluidmaster fill valve plastic 1/2" fitting. After being installed with a B&Q slimline toilet had to keep adjusting as when...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
