Discuss Electrical box to valves behind heating pipes? is this safe/ok? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need more official and professional opinions om my situation.
It looks like the electrican and plumber have built something that I'm not sure is safe.
Please can you confirm.
The electrical box is sitting behind the heating pipes and the electrical box is touching the pipes.
is this safe?
a picture
Yea not right as you can't get to it for access/ replacing
Non but very bad practice
Surely if you can't put a non-maintenance-free junction box under a floor unless there is a dedicated access panel, and that electrical box cannot be accessed for maintenance, then logic would suggest that unless the electrical box has maintenance-free (i.e. non-screwed) terminals, it is in violation of a similar reg?
But you'd need to check on our sister forum as that's presumably where the sparkies live.
they cant be put under floors now, only where you can get at like gas comp fittings
Page 9, paragraph 4 would suggest you can't put them under floors 'unless provision is made for access'. Not that I would, even with provision, as it only takes someone to lay a posh carpet or some tiles, and bang goes the provision.
Unless this link is out of date?
hager.co.uk/files/download/0/2801_1/0/Guide_to_Junction_Boxes.pdf
Not good but easy enough when replacing head to cut cable and use junction box to connect new head. I do this on all mv changes so I dont have to go into wiring centre.
Not ideal but see it all the time who's to blame engineer or electrican ??? in all honesty both . cheers kop
That's why I do the wiring from the fused spur. Sparks get a bit lost with heating and controls wiring. I always make sure wether It's a heating part or electrical box It's accessible as possible. Just incase it's me coming back for maintenance/repair.
Reply to Electrical box to valves behind heating pipes? is this safe/ok? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First...
2K
