Discuss electric shower problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Bless
Hi i'v got a electric shower to take a look at tomorrow. it's got power running to it but no hot water. has anyone got an idea what the problem is?
Many thanks for any advise.
It'll cost more to diagnose and fix than replace. How old is the shower?
Or it could just be a ÂŁ20 part that needs replacing.
Yeah, and the labour charge for 2 visits repairing shower and the wait for the part. What's the point? May as well have a whole new shower.
Quite possibly. But I'd charge a min of an hour to diag and then another hour to replace said part. Why not just change the whole thing and get a better shower with a guarantee?
Yeah true, you can get cheap showers for from ÂŁ50, which includes at least a years warranty.
Also you repair you are suddenly the unlimited warranty provider. Bang in a new one...up sell a water softener IMHO
And then there's some showers that don't have any serviceable parts, like the some of the Gainsborough range, where you have to change the entire 'engine'
why, I'm allowed to plumb in and connet a replacement shower. normally when they fail to heat up the have burnt out. other problem is over pressure valve giving way needing the little ball popping back in if you can find it. All other issues need parts ordering at labour v new shower costs apply hence new shower. remember sparkies and water dont mix, they do not like to be wet in their jobs:D
It is a grey area which I am sure some boffins will be working out a way that they can charge us for a course, certificate or badge that " allows " us to do what we have done for decades. BTW don't get me onto electricians
If most jobbing plumbers checked their insurance if they touched electrics, it would be null and void unless trained to undertake.
Probably means the light on the pull cord is on therefore it must be the shower? Not necessarily. Take a pull-cord switch with you.
You've got part P then.
No just lots and lots of common sense and experience through years of work in this industry, and I gave up counting how many times Ive followed up after sparkies even those with a part P who leave leaking immersions (pretty lethal) and dont know how to wire up a s or y plan . Any more smart arse comments
check your inszzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
how you know fuse and circuit is up to spec ?
Fit a new one, but cable will have to be current regs which is 10mm twin and earth. Triton Enrich is on sale at Screwfix for only ÂŁ50.
10mm. Why?
To take the load without overheating the cable. All showers of 8.5kw and above must be 10mm twin and earth minimum. If the cable run is a long one it should be increased to 12mm.
Reply to electric shower problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
