Discuss Dual immersion heater question in the DIY Plumbing Forum area at PlumbersForums.net
I recently posted to request information about supply of a "dual Immersion heater". Two members kindly replied with helpful advice.
I tried to respond with thanks but the system persistently refused to accept this; quoting:
"Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator."
I cannot find any way on the site to contact an administrator.
So, this is the only way I can say "thank you gentlemen"!
Your help is much appreciated.
Regards. shackec
Forgot to mention yesterday, you'll need additional wiring between the On/Off- Bath/Sink switch and heater.
Currently between your existing switch and the heater (assuming you already have a single one) you will have L, N, E, for the Dual Heater you'll need L1, L2, N, E.
Not too much of a problem if the switch is at the location of the Immersion heater
Thank you for the response
Reply to Dual immersion heater question in the DIY Plumbing Forum area at PlumbersForums.net
