Discuss DT92E roomstat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
kozak1968
Customer has a problem with a Honeywell Wireless DT92E roomstat. The receiver has no lights on at all showing and the remote is blinking the signal sign. The customer says no lights even when the receiver is pressed. Any ideas before I have to make the very long journey over there to check it out.
batteries ok? if yes just replace the whole reciever unit as there know to go duff
Try re matching the unit to the receiver. They occasionally lose communication if the batteries have been low for a while.
Reply to DT92E roomstat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame to call for heat, and the receiver seems to be working ok with green light, but heating is just not firing. I really am not sure what the problem is...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed function, it'll switch off at the programmer (no light) but boiler will stay on until they turn the stat down, I went and looked at it, they said they...
2K
Hi I have a 4 zone / 7 loop UFH system. 2 zones (4 loops) always get hot when the system is on when the zone thermostats and actuators are off. The video posted shows when I turn on another zones the flow meters drop. (Kitchen prep and kitchen TV are the issue, two at either end of the...
1K
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View: https://youtu.be/Touvx2c3RJE ">this video</a> I took when turning it back on this morning (it had been off overnight) - it shows the behaviour, but if that fails, all the...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s house has a pump which pulses on and off every time a tap is opened. Even filling the bath (pressure is strong) the pump won’t come on and stay on but...
