Currently reading:
Does sentinel x800 need neutralising crystals ?
Discuss Does sentinel x800 need neutralising crystals ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dholi85
Basically what the title says.
Does sentinel x800 need neutralising crystlas?
no, its not an acid type cleaner. use as instructed on the bottle and you will be fine. If you want to be doubley sure test the ph levels at the end of the flush are the same as the cold water mains ph.
No but same thing as AW says get the pH right or stick a tds meter on the drain off when your flushing it out to make sure you get it all out.
Reply to Does sentinel x800 need neutralising crystals ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
