Discuss Danfoss HIU Filling Loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, hoping someone out there can help.We have a Danfoss HIU. The pressure is down and have been told to fill the system. I've connected everything as shown in the pics but the gauge isn't budging.
[/IMG]
Left hand gauge is reading 0 so you have no water pressure or a faulty gauge ?
Also what's the silver valve for just out of the pic top ??
Yes that’s right no pressure. Hence why I’m trying to fill it. Not sure what the valve is for, it’s hot and cold joint for what is marked with a factory symbol. Grey water perhaps?
That's your incoming cold mains that has no pressure/ gauge is faulty
Do you have cold water to your taps ?
YEp, all taps working fine. Judging from the manual it should be reading 1.5-2. There’s definitely mains pressure as when I disconnect the pipe from the inlet it rushes out. It’s not getting in. I presume the gauge is correct as the radiators are still cold, or Luke warm at best.
If you disconnect the hose from the heating side and turn on the inlet does it come out of the hose. (Prove the hose is not blocked)
If it’s not blocked, open the heating valve into a bucket to prove that opens. If that works it could be the heating gauge is faulty.
Just checked, water is flowing from both. But if the gauge is faulty why is there still no heating?
any of the pipes warm above the unit?
does the heating work?
Reply to Danfoss HIU Filling Loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not doing the job but he wants to know what to buy and replace it himself and asked me where to get one. I said I'd have a mooch. He sent this picture. I...
Can anyone help me identify which tap/connection it is to top up the system as the level has dropped quite a way below the red marker for the cold fill pressure on the gauge? Boiler was installed approx. 2014. I've looked in the manual & online but can't find anything. Many thanks
Hi, I need to install TRV on 3 rads in my flat. I'm looking at my Danfoss HIU (picture attached). I cannot workout how can I top up the pressure if I were to drain the system to install the TRV. I might need a filing loop for this. Anyone familiar with this HIU? Another question, would it be...
3K
Deleted member 120897
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s house has a pump which pulses on and off every time a tap is opened. Even filling the bath (pressure is strong) the pump won’t come on and stay on but...
