Discuss Corrosion on pipe connections. in the USA area at PlumbersForums.net
Perhaps I'm missing something but isn't this just melted insulation sticking to the pipework
no that's rust and rot.. compare the two top and bottom.. especially where the threaded section on the tank is.. that's where the leak is..
The first image seems to show a trail of corrosion running vertically down the white tank. Could it be a leak above the fittings is letting fluid run down and corrode the lower ones?
I would be contacting the manufactures of the solar cylinder for their input is there a sacrificial zinc/Aluminium anode installed ? In the unit ? if this has failed then it could be the cause,?.. kop
Reply to Corrosion on pipe connections. in the USA area at PlumbersForums.net
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
Evening all. Can anyone help me with a bit of advice. We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old)...
Deleted member 120897
Hello folks, I am hoping some of you may be able to provide you perspective on what is looks like could be a serious problem. I am a complete...
2K
Apologies for the stupid question, I'm just a newbie playing under the sink. I have an isolation valve and an elbow, both of which have...
3K
Hi all, had some great advice on this forum and need a bit more... I've used this reducer (pictured) to step down a 22mm lead loc coupler to 15mm...
3K
