Discuss Corrosion on pipe connections. in the USA area at PlumbersForums.net
Chaps,
I'm in Tenerife looking after a few houses. They are only 3-4 years old and this is the second solar tank to fail due to severe corrosion on the collector connection.
Has anyone got any ideas why this should happen and both failed on this one connection after such a short time whereas the other connections seem unaffected?
Thanks for sensible advice.
The stuff inside the pipes are very corrosive and by the looks of it as the valves off it’s just sitting there tbh looks like it’s needs a new system
Thanks for the reply
they don't tend to use inhibitor here so it's just water to>from the solar panel
The valve(s) ware turned off to stop the leaking after the event
A new tank is being ordered monday but what we don't understand is why the bottom connection is clean and yet this one is rotted out (same as another villa)..?
It’s the hottest connector on top
40dc cooler
Top one would be around 80 bottom 40 ish also the higher the temp depending on how old the liquid in the system is it becomes very corrosive
40dc cooler
40c? If the hot water cylinder is sitting at 70c I cannot see how the water entering is over 110c+. to get anywhere near a 40c ?. Plus it's corroding from the outside not inside or it would pinhole leak before the outside corroded so badly?
Perhaps I'm missing something but isn't this just melted insulation sticking to the pipework
Reply to Corrosion on pipe connections. in the USA area at PlumbersForums.net
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
Evening all. Can anyone help me with a bit of advice. We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old)...
Deleted member 120897
Hello folks, I am hoping some of you may be able to provide you perspective on what is looks like could be a serious problem. I am a complete...
2K
Apologies for the stupid question, I'm just a newbie playing under the sink. I have an isolation valve and an elbow, both of which have...
3K
Hi all, had some great advice on this forum and need a bit more... I've used this reducer (pictured) to step down a 22mm lead loc coupler to 15mm...
3K
