Discuss Copper waste to Plastic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
FrankieF
Heys guys,
Need some help. I have to fit a 32mm waste pipe to an "old" 1 1/2 inch copper waste, all internal piping, so cannot remove the copper pipe, so stuck with it unfortunately.:mad:
I know there are some fittings out there available, but do you know where I can get them.....?:confused:
If not, can only think of quick fixes, but not a choice i would like to choose......:eek:
Any help would be greatly appreciated.
regards
Frankief
1 1/4 " flexible compression will do it available from any plumbers merchants.
Ive got a feeling that a normal 11/2 push fit fitting will go straight onto the copper, failing that as said mechanical coupler.
did 3 of those before xmas, you need 1''1/2 compresion to short flexi. that will sort it 100per.
if you are going from 11/2" copper to 32mm, best to use a 38mm McAlpine multifit straight coupling with 38x32 reducer in it, (dont use crappy multifit from Q&B etc they are mince)
agree mcalpine for me to
Reply to Copper waste to Plastic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
