Discuss Connecting values to towel radiator help needed in the DIY Plumbing Forum area at PlumbersForums.net
Hi there. I’ve installed a new towel radiator and I’m trying to fit the valves but I’ve come unstuck and need some help.
I’ve bought new angled valves to replace the old ones but I can’t connect them. I think I’m missing something.
They are the right size to screw into the bottom of the radiator, but the valve head is too big so it’s not a tight join
the radiator comes with a connector but the valve dont tighten on them.
See pictures. Apologies if this is something really obvious. Am I missing a connector?
Thanks in advance
😂 there should be another tail same as the other side
Your picture in post #5 is how you do it.
Slide the valve onto the smooth tail, yes it can just fall off again, but then you tighten it with a spanner and the copper olive is compressed - this not only makes a water tight seal but it also stops the valve falling off!
Reply to Connecting values to towel radiator help needed in the DIY Plumbing Forum area at PlumbersForums.net
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
Hi we moved into our house last summer and it wasn’t until winter we started having problems. We couldn’t get the radiators to work until my dad...
Deleted member 120897
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
