Discuss Condensate pipe fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bert large
Seem to be getting a spate of leaks of condensate pipework after it's been fitted a few years where the solvent cement on the fittings appears to be getting eroded away by the condensate.
Anyone else getting this problem ?
Only on the small style condensate elbows they fall off , the deeper ones (think osma) are fine.
Fine by me tho as its easy money .
I've had it on all makes for some reason, doesn't look great when you go back to your own install, 2-3yrs later.
Yeah I stopped using plumb Center condense as the insert depth is too small... Plumbfix stuff is good quality, good insert depth...
The only leaks I notice on the glued fittings are the original worcester Combis with that horrible grey adapted, people glue them but I'm not even sure if there suitable for gluing as if you touch them the joint breaks!
the overflow pipework just gets brittle in general and falls apart!
On another note, I wish o/flow pipe was a standard size across the board instead of the slight difference between manus
Oh well,the joys of the common market I spose
Defs agree with that... What a pain this is always!!! Larger waste pipes seems to be so should the small overflow! Keep a mcalpine compression condensate coupler on the van to solve lol
Glad it's not just me then. I was beginning to get paranoid
I use overflow fitting from City. Think they are Osma.
It seems solvent cement isn't entirely compatible with condensate.
Switch to 32 as soon as space allows it, its what i do, even indoors. Hate that 21.
last one I installed went straight into a washing machine trap, ideal solution no 21mm to be seen
Reply to Condensate pipe fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
I was just interested if people put solvent weld on both the pipe and fitting or just the pipe when glueing overflow/condensate pipe.
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
