Discuss Cleaning unvented pressure reducing valve / inlet filter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassafe
Has anyone dismantled these before... The water pressure / flow rate has dropped right off on the hot & cold outlets, I suspect the inlet filter is full of debris. I only recall changing one of these once & it took ages to pull out as it was a pig of a job! I'm referring to the big plastic cartridge element!
Im looking to pull it out first to check as there not cheap / hoping it will only need cleaning, but kinda worried it won't come out in one piece & I'm gonna end up in a right mess!!
I don't want to buy one as there about 80 quid which will be wasted if its a wrong diagnosis, the property has a few different incoming mains so not a straightforward property :/
I'd buy a new one or get one on a note just in case you need it once you've started, nothing worse than getting half way through the job and you need a part that you could of brought
They do break, take it off and from the balance port, get a punch / drift and carefully knock it out from the bottom. Use the palm of your hand well before a hammer , good luck .
Just changed 2 last Saturday
Water hot water ran then stopped.
Changed valves & all beautiful
Was with a suitably trained engineer!
The one I bought was ÂŁ93 inc vat I think at plumb centre.
I did try Williams first so not to upset Ray but they don't stock the megaflo ones & I wanted like for like.
Definitely not the same. Thankfully....
Theyre supplied with the RM cylinder. Range Tribune too.
I replace cylinders and unless they need changing, I don't bother. Saves having to change pipework as you'll have to do.
Just give them a price to supply and fit a new one
Just looked at the pic, properly....
That's well and truly buggered by the looks of it - check out the limescale stalagmites growing from it. Full of rust inside
Cheers, will get a replacement ordered as iv got a range one spare myself but its different with the expansion valve missing lol! Yeah it looks a bit funny, but I'm not sure what the inside will be like!?
Reply to Cleaning unvented pressure reducing valve / inlet filter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years...
Hi all. I recently ordered two separate water filtration systems (the cartridge type) from a local plumbing company. For both installs the pipe...
