Discuss Central heating pump running at random times? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Templar
Hi folks, i wonder if you could help me? My central heating system (about 4-5 year old worcester Greenstar condensing boiler with a honeywell controller and a grundfos pump) runs from about 06:00 until about 22:00 as per the timer. But over the past few weeks the pump has started running for short spells during the night? At maybe two or three in the morning, only for ten or fifteen minutes, but at the moment, we are not getting cold enough nights where it could be coming on for frost protection (night time temperatures never dipping below 10 degrees at the moment)
do I have a controls issue or could there be another reason?
Thanks in advance for any help you may be able to offer!
Sounds like you need a heating engineer ( gas safe registered), sounds like a boiler issue
Are you sure it's the pump running and not just the boiler pre-heat?
If there's an eco mode on there, turn it on and if that stops the issue it's just pre-heating which nearly all combis do.
Don't think it's a combi mate
If the Honeywell thermostat has batteries, try changing them.
Honeywell thermostats start doing weird things when the batteries go flat.
They are meant to have a low battery symbol that comes up, but have had countless experiences where changing the batteries in the thermostat fixes a lot of problems
Reply to Central heating pump running at random times? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs mostly at night. I'm sharing video showing the problem: So far we changed: 1. Expansion vessel 2. Pump 3. Water pressure gauge - analogue sensor...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
