Currently reading:
Can't find refilling loop...
Discuss Can't find refilling loop... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nw8926
Can anyone tell me what type of boiler this is? It's lost it's pressure after the radiators needed bled. I can't find the loop to add more pressure, any ideas on where this could be image.jpg
image.jpgSurely it wouldn't be behind the tiles?
Check in old airing cupboard or cupboard under/to the side of boiler for a silver braided hose with a valve on it
Looks like a Biasi. The filling loop could be pretty much anywhere - I'd have a look in the cupboard below the boiler to start with. If not there, then no idea!
the answer to the last question is
no it shouldn't be behind the tiles,
but anything is possible, happy hunting
Identify the cold water rising main at the boiler and follow it back to find fill loop. This will be at a point convenient to the flow and return pipework but not necessary near boiler. It would usually be where pressure gauge on boiler can be seen.
Probably behind the tiles , looks tight but can you get a mirror and try look behind the tiles
im only guessing but I would also say behind the tiles, if any of the grout lines around a tile is silicone then they might have left an access tile ? probably not , some people don't think .
Reply to Can't find refilling loop... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
