Discuss Boilermate 2000 no hot water at all...not even just from immersion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you are not Gas Safe registered you should not have cover off that boiler as it forms part of combustion seal.
Close it back up & call in an accredited GSR engineer.
Cheers,
Andy (Allgoode)
Put the covers back on and call a gas safe engy
As unless your gas safe you can't remove any covers / case seals
No no no ! you cant do that put the casing back and call a GSRI probably a simple solution but nothing you can do yourself . kop
Reply to Boilermate 2000 no hot water at all...not even just from immersion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
