Discuss Boiler electrical isolation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Thought isolation should be via a plug or fused switched spur? Came across one today that had just an isolator, no fuse.
was it on its own supply? or off the ring
if oof the ring needs fusing
Reply to Boiler electrical isolation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
