Discuss Blocked Flue Vents Solid Fuel Boiler (Trianco TRG45) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dom_trig
Was wondering if anyone might have any tips how to get the rock solid soot build up cleared from the flue vents in my Trianco TRG45. They are not completely blocked and have sufficient airflow for the boiler to run but cannot get the flue vent cleaner tooldown the vents. I think this is due to hardened soot that i have tried brushing, chiselling etc. The main difficulty is the access. Has anyone had any experience with anthracite boilers?
Many thanks in advance
Dom
Dom
Hi we have same problem as you did, did you manage to resolve it? Any tips would be gratefully received!
Reply to Blocked Flue Vents Solid Fuel Boiler (Trianco TRG45) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has been serviced regularly over the years by different engineers with no issues. Last time , the guy wanted to condem it due to not being compliant with...
I live on the 3rd floor of a 6-story block of flats. (26 flats in total). During the evening when all people are inside their flats and using their boilers to heat their flats, there is obviously lots of steam coming out of all the different Boiler Flue Vents. if I open my window or go outside...
Hi everyone, im not sure if this is the right forum but here goes, So i have noticed after getting my chimneys cleaned out that the soot from my kitchen chimney is damp and it looks like my old solid fuel back boiler has a leak of some kind. the boiler was put in when the house was built in...
4K
Hi all, came across this forum this looking for information on my sooting up kitchen type indoor Enviromax. I'm a retired electronics/maintenance engineer, (fwiw can answer questions on popular smart home thermostat systems), but I've installed many solid fuel boilers in the last 40 years for...
2K
  • Locked
Was have a trianco trg45 boiler and one of the flueways at the back has become blocked solid. The tool provided can't shift it and it's awkward to get at. Is there a chemical or something I can use to soften up the compounded soot. Any help would be gratefully received
