Discuss BG F2 boiler pilot light (a simple question)! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
paulbrighton
Could any of you advise whether the pilot light on a British Gas F2 boiler (F2 - 60) is supposed to be permentely on? (excuse spelling)
Reason for asking is that when we first moved into this house 5 months ago I would have sworn that pilot was not constantly on and now it is. I may of course be totally wrong but am now intrigued and the BG installation instructions do not appear to cover this nor do instructions for a potterton which I found online (same or very similar boiler I believe).
This will lead to a new posting on boiler overheat cutout suddenly starting to occur but that can wait for more investigation before I post about it!
Many thanks /Paul
First of all are you actually having an issue with the boiler.
Secondly please read ALL the notices pertaining to gas and appliances.
If I remember correctly then this boiler is just an old potterton rebadged as a BG boiler.
If I'm right then it does have a permanent pilot light, so there's nothing wrong with your boiler :)
TE=villa_tom;644652]If I remember correctly then this boiler is just an old potterton rebadged as a BG boiler.
If I'm right then it does have a permanent pilot light, so there's nothing wrong with your boiler :)[/QUOTE]
Thanks villa_tom. That helps greatly (ps yes it is a rebadged potterton)
Hi Croppie, Yes I have read notices a pertaining to gas and appliances and yes I am having an issue with the boiler (regular tripping of overheat stat).
Possibly you can guide me here. I am a competent electrical engineer perfectly capable of diagnosing faults on the circuit side of boilers but as I am not GSR does that mean I cannot even look at the boiler electrics (obviously provided I do not touch the gas side) ?
OK croppie I bow to your experience. It is a confusing situation though because, if I understand you correctly, that would mean a sparks cannot connect the control circuits to a boiler unless he was also get ?
Sorry meant to say GSR and not get in last post Doh! Auto correct on this tablet:oops:
More often than not yeah. Depends entirely on whether the case is decorative or forms part of the combustion seal.
If it's the latter you most definitely can't.
I'd take a wide and sweeping view if I were you.
Thanks croppie - control wiring under the case so checked out without removing case. Pump overrun not wired correctly if hot water only selected on programmer - no issue if both CH and HW selected. Bugger to find but now rectified.
Reply to BG F2 boiler pilot light (a simple question)! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. New to the forum and I thought I would post a question. I have a Potterton Performa 28. I have had it serviced by the same chap...
4K
  • Locked
Hi, Looking for some advice on our boiler system. Our have a Potterton Promax SL boiler combined with an unvented santon premium plus hot water...
2K
  • Locked
Hi, and merry Christmas to everyone! My boiler has stopped working properly and so I have no heating or hot water. Everything runs but the...
Rickster123
R
R
  • Locked
That should read Stelrad Ideal RS50. I have the above boiler that has been turned off for 3 months during a full refurb. I have no Idea if it...
1K
Dotty
R
  • Locked
About 4 weeks ago I had no hot water and there was a vibrating noise which seemed to come from the hot water pump in the airing cupboard and go...
3K
