Discuss Steel rad Ideal RS50 Boiler Pilot Light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Radioman
That should read Stelrad Ideal RS50. I have the above boiler that has been turned off for 3 months during a full refurb. I have no Idea if it worked before or not. I cannot get the pilot to light. My question is should the green button be pushed towards the back of the boiler to light or pushed sideways and in? There is gas up to the valve.
Sorry. Please read the forum rules and get a competent gsr in.
If you've no idea whether or not it's worked before it would be a very, very good idea to get it checked over.
For your own safety if nothing else.
Reply to Steel rad Ideal RS50 Boiler Pilot Light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
The boiler runs may be 1 or 2 days before erroring. The problem started 3 months ago. The boiler would run blue light on at front an center of...
Deleted member 120897
I live on the 3rd floor of a 6-story block of flats. (26 flats in total). During the evening when all people are inside their flats and using...
1K
I don't work now due to being ancient. I looked at a 'Range cooker' fired on kero. It had a slow leak that turned into a bad leak in a month! It...
2K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
