Discuss Best way of reducing rad. Valve to 10mm in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Which is the best way of reducing a rad. Valve down from 15mm to 10mm. A soldered reducer or an internal reducer?
Long tail soldered reducer better in my opinion
Or a pushfit 15-10 elbow adapter
Thanks as long as the one in my picture. Looks Abit over kill as the olive just need to be back past the shoulder. But that's all my merchants have.
You can cut them down to match the depth of the fitting
Slice or manual cutter eg tighten the wheel etc
Why not buy 10 mm radiator valves? My plumber fitted 10 mm TRVs (Inta I-Therm 10/8mm White Angled TRV 108TRVA) and I later fitted 10 mm lock shields when I replaced the radiators.
Yes but taken 15mm ish off the top
A point nose pliers on the bit your cutting off etc
Don’t worry about the flow, the big restriction is in the valve.
Any of the above methods are fine, it’s just about the aesthetics- which to be honest will be overlooked within a few days !!
Reply to Best way of reducing rad. Valve to 10mm in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
I’m replacing my single skin plastic oil tank with a new bunded oil tank. I’m going to replace the single 10mm pvc covered oil pipe too, so to...
I have Honeywell Valencia TRVs 10mm pipe size, I’m making mods to accommodate larger rads and it looks like the 10mm compression insert is special...
Divy here thought his cold water feed was 15mm.. so bought a 15mm - 1/4" reducing tee to plumb a fridge. It's 10mm!! I've already cut it so stuck...
