Discuss Bath Drain Tool ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mike555
Hi
Is the a special tool to tighten and loosen this drain fitted to a bath?
All the screwdrivers I have that are wide and will reach the two slots are to thick to go in them.
Mike
I use a wood chisel.
Mind you the wood chisel I use would not chisel wood.
It's a Plumbers chisel - used for anything - except chiselling wood.
Works great for the application you require.
Try that!!!!
20p coin held in a pair of pliers.
Or for Yorkshiremen, a penny pinched between the fingers...
Would that be the 'fabled' first penny their ever earned....
....God Forbid......
.....I was led to believe that was to be framed!
It's a little known fact that copper wire was invented by two Yorkshireman fighting over a penny...
Plumbers chisel for the win, bath wastes, strainer wastes, bosting holes in things and general wedging
Another wood chisel user here.
Reply to Bath Drain Tool ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Sonya K
