Discuss Balanced feeds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
flappy8
Morning,
I have two questions....
I presume that taking a toilet cistern feed of the balanced cold is fine and itdoesn’t need to be run back and connected before the PRV?
On a kitchen sink we have a mixer - Can we run a cold feed pre the softener, andfit 1 2bar PRV so that it matched the balanced and connect like that?
Yes to both.
Kitchen taps have separate spouts for hot and cold. I'd only fit a prv if it's difficult to control. Its usually fine.
Yes to both.
Not all do. Check the mis if it says to fit check valves then it is likely the waters mix in the spout or body in which case fit check valve and given pressure reducing valves are not mega expensive I would fit one on the unsftened cold to the kitchen tap too.
Reply to Balanced feeds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If changing a combi boiler system to a heat pump. What do they usually do with the balanced cold connection on the hot water cylinder? Cap it. And...
1K
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's...
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is...
2K
