- Messages
- 5,439
[DLMURL="http://www.toiletspares.co.uk/page_29.html"]Washers & Bolts, doughnuts, isolation valves and toilet essentials.[/DLMURL]
Second and third items down are a service valve and a convertor bush which I think show the same size of washer designed to replace the fibre washers that come with service valves. I'm thinking they might be too baggy over a standard tap connector (because you get two different sizes of fibre washer for service valve and tap connector) but for changing taps or doing awkard ball valves these might be very handy. Shouldn't need to spend 4 quid on a service valve to get one though, if I knew size of rubber washer might be able to buy a hundred somewhere for pennies.
