Discuss Rubber or fibre washer fill valve connections in the USA area at PlumbersForums.net
Matt0029
Any one started using rubber washers on copper tap connectors instead of fibre?
I’m using rubber these days
On number 62s/63s? Discarding the supplied fibre washer and fitting a rubber one? I have been with the chrome service valves and have seemed to seal alot better.
Yep find I can’t get a decent supplier of fibre washers there so thin and have too much slop eg Id is too big these days
Yes use the hep ones
On end feed tap connectors? Can you ruin them by going too tight with being rubber? Usually do them up pretty tight and never had an issue though.
yes on flat face no you could cut them if your going into an iso valve eg compression
Reply to Rubber or fibre washer fill valve connections in the USA area at PlumbersForums.net
