Discuss Additional PRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
just looking for a bit of confirmation. I've got a Combi with a PRV letting by. It's not the easiest position to replace so I'm thinking I'll just add an additional one on the PRV pipe work. Apart from making sure that it's set to the same max pressure is the one inside the boiler I can't think of any reason why not to do it. Am I right?!?!
Thanks in advance
So, you will then have:
1 pressure relief valve still letting by
And 1 extra pressure relief valve which won't be letting by.
Just get some one in who can do the job.
For one your not gas safe reg as you would need to take the boiler cover off so sorry to say anyway what your saying won't work
Get a gas safe eng in
It's letting by for a reason, probably a very easy fix which won't be shared on here I'm afraid. It's not an expensive job. My advice, get a GSR plumber in and rest in peace knowing it's done right and most importantly, safely!
A you're not qualified to do so And B it will be modifying the appliance not necessarily in line with the manufacturers instructions
Reply to Additional PRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the...
