Hi, What are peoples opinions about an 8mm-10mm reducer compression fitting. I am about to have the plasterers in and wanted to get rid of the visibly annoying 8mm pipes - the plan was to compression fit beneath the floor boards to 10mm speedfit and then up through the back of the rads and on to Peglar push fit reducer bends (10-15mm), mounted to a 15mm TRV/lockshield.
I'll probably get rid of the 8mm where possible in the long term as whole carpets come up, where I'll use a new compression joint to tie into the 10mm speedfit pipe. Until that day however I think it's worthwhile converting the visible rad runs to centre exit whilst the walls are being filled.
Any flaws in my plan?
Tim
Tim
