Discuss 8 ball Pool app in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumber0808
8 ball pool app. Try it Its addictive, you play against other users for money and build up your own score.
its not for real money i hate it when i loose, but you build it up for some reason.
I'm so competitive I can not stand loosing
Is there a sticky for apps?
edit: the money allows you to buy a better pool cue. Wooooooo
Reply to 8 ball Pool app in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone! I purchased this steam vent valve: Hoffman Steam Air Vent 40, 1/8" Angle Steam Radiator Air Valve 401440. Installed it and the...
Hi everyone, a bit of an unusual post again but really at a loos with this one. I'm a little paranoid since I've worked for, and with cocaine...
Sharp Point
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
Hi from the USA- I'm a plumbing engineer and master plumber in the USA who is going to be building a new home and plan on using European wall-hung...
2K
  • Locked
Hi, We have a problem at home with water coming from overflow pipe from the cold water tank in the loft. Now i know the most common fault is the...
3K
