Discuss 56v on neutral in the Gas Engineers Forum area at PlumbersForums.net
Evening
I've not posted for a while and have had to set up a new account as I can't find my old one.
Moving on I have a wiring conundrum.
Customer called said heating had died no lights on programmer. At the property the customer also asked if I could change the honeywell wiring centre (with pcb) as it was in pieces whilst there. Stupidly I did not check neutral to earth etc before starting apart from if there was a live to backplate with death stick. So changed programmer and just put in a honeywell junction box with no pcb. Turned spur on and boom - breaker goes out.
After much effort of checking disconnecting etc I couldn't get the breaker to stay on. Fuse board was breaking on mcb and had two rcds. In the end I had a new fused spur wired into brand new programmer only (literally nothing else) this time when I put the spur on the breaker broke again. I then checked the programmer on a fly lead from bedroom sockets and it worked perfectly.
I Advised customer that a new wire from the board and fused spur is needed (retired spark- he agreed) meantime I wired heating back together and run off a fly lead from bedroom sockets and three pin plug fused to 3amp. Three port moved to hot water only to mid to heating only perfectly boiler pump all working..
Customer runs new cable and tests with socket tester which said fine then puts in fused spur. I go back to today. Remove fly lead and put into spur. Turn spur on and exactly the same problem. I wire back to fly lead/plug and all works fine again
Has anyone got any ideas. Thanks in advance
I'm not an electrician so I'm not sure I'm thinking along the right lines. Where you getting this neutral voltage at the fused spur?. @Murdoch can you explain the possibilities for the above problem?
So you have 57 volts between neutral and earth on incoming to spur and as soon as you flick the switch the mcb trips? And that was the same with a new fused spur and just a programmer?
He replaced the spur with a new unit (although not proved faulty as well) and still the same. Could this be a broken neutral problem somewhere? Was an initial thought of mine but like I said I'm not an electrician
Reply to 56v on neutral in the Gas Engineers Forum area at PlumbersForums.net
Looking for a gas safe engineer to complete a boiler and cylinder install in Ringwood BH24. There was a delay of approx 8 months from the install...
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I...
hi all , had a strange one this morning, boiler just went off ,dead no lights nothing. checked electric no power cuts everything else on in house...
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to...
