Discuss 42cdi or unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've been to see a customer who wants better water pressure, he wants a shower cabin, he's on gravity now and gets about 6 litres out of his mixer taps on the hot side. &nbsp;Can fit a big combi for the flow rate, he is getting about 16litres a minute out of the cold. &nbsp;However I spoke to megaflop, they said it's not enough for unvented. &nbsp;Any advice?<br><br>thanks everyone.
What is the water pressure? Working? Have you considered an accumulator if the main can give you enough?
Reply to 42cdi or unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
J
Boiler broke over Xmas and needs replacing and I’m tempted to move away from our 1985 gravity fed system and get a combi as many other parts of...
Jack Canfield
J
I'd like to install an unvented cylinder in the loft. With limited headroom it would have to be horizontal. I want to keep my existing valiant...
2K
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
I currently have an 8.5kw electric shower on a gravity fed system in bathroom which doesn't give great flow when hot turned up but to get a 10mm...
