Discuss 40mm to 42mm chrome plated brass compression joint? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SimonSmith
Does such a thing exist (40mm to 42mm chrome plated brass compression joint)? I'm have a nightmare trying to marry my shallow seal bath waste with existing 42mm pipe-work. Thanks in advance for any help.
Thanks steveb. Yes, I've seen that one. But isn't that 42mm to 42mm, or am I mistaken? Mcalpine code 42G-CB, is that it?
Reply to 40mm to 42mm chrome plated brass compression joint? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi all, I'm in the process of fitting my freestanding bath. The supplied waste chrome pipe that runs into the floor is an unusual diameter -...
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new...
2K
