Discuss 3 port motorised valve wiring question. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening everyone,
Question 1
I have just replaced my 3 port motorised valve head and wired it in.
When looking at my chocolate block connector the orange and grey wires are in different places than the diagram on the instructions shows.
As you look at the terminal block for all the wiring, there are 10 segmants to the chocolate block.
My wiring shows no 8 on the choc block a grey wire and no 7 on the choc bloc a orange wire.
On the instructions,no 8 shows orange and no 7 shows grey.
Could someone please tell me which is correct.
Question 2
Could the above wiring problem affect my heating programmer as I now can't have just hot water without having the heating on aswell.
Before I wired in the new valve I was getting heating on with water aswell.
The programmer seems now to be working the other way round.
The programmer is a Honeywell ST699.
Thanks everyone.
Dal
Question 1
Question 2
Thanks everyone.
Dal
What make is the motorised head?
Banico are kind of a Honeywellreplica.
if memory serves I am pretty sure that their heads are interchangeable. Have had a problem with a few of them failing in a short space of time
Thanks Riley.
I have replaced the head and wired up exactly as the wires came out.
I used to put the heating on at the programmer and always have to put the water on aswell otherwise the boiler would not fire up.
Since changing the valve and wiring it in I have to put the heating on and the water which means that when summer comes the rads will be on.
Cheers Dal
Question 1
Question 2
Thanks everyone.
Dal
Have a look here, doesn’t mention which numbers:
https://www.banicocontrols.com/uploads/media/instruction_954311.pdf
Reply to 3 port motorised valve wiring question. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hay, I'm learning fault finding in CH systems which I'd need help with, please. I've been given a set example: have got hot water but heating...
1K
Hi, i am replacing a 2 port z5 drayton valve with a 3 port mid position drayton. Can anyone please tell me what changes i have to make to the...
Deleted member 120897
Looking for a gas safe engineer to complete a boiler and cylinder install in Ringwood BH24. There was a delay of approx 8 months from the install...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
