Discuss 28mm metric to imperial... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Anyone know where I can get these? And can I file the ring down to make em a slip coupler
Fine sandpaper on the inch pipe and then a 28mm compression will fit with a bit of a tap.
Handy to know for future guys but this isn't as simple as that. This pair of gravity hot water pipes are so close together I will only just be able to get a fitting on. Also, they are so close to the bottom of the floorboards that a compression fitting would make the board protrude. This is what happened, I pulled up a carpet to to get to pipes some where else and saw a little nail sticking up, so I gave it a little tap and then wished I hadn't. Right at the end of the day too!!! What fun☺
Should imagine BSS would stock them but better be sitting down when the invoice comes through the door!!
Don't know how it fits with where you're based but Brentford shows 1, Croydon 6 on the availability check, it's usually fairly accurate.
Ah no way thanks feller for looking into that, I am in south ealing tomorrow so close to brentford. I am not even sure where plumb centre is in Brentford. Unless it's the one that used to be in Isleworth but moved
Re the price, on the website 35mm Endex equal tee £43.14.
I paid £10.42 + vat. each for some last week on our Wolseley account. (National coverage company)
just use a normal 28mm coupling soldered or comp doesnt matter fits its only 3/4 you need to change
cant you tack it?its not gas,done a tack repair a few weeks ago on a similar set up,only difference,i did not put the nail through,sparks did
Ive got a rothengerger expanding kit just for said job. Be careful trying to solder 28mm couplers filed and 15mm to imperial cos the solder doesnt always run true because of the gap needed. compression for them or expand the fittings and either expand the pipe for 3/4 or get some proper couplers or green olives for a compression fitting.
ive never had a problem over the years and reguards to 15mm the wall is thicker so the id is slightly smaller nothing to do with od
The old imperial 1/2" has a slightly bigger od and some is greater. Seems odd that it varies I know, but is true.
As to the OP, I use 28mm brass connector on an appropriate position on an 1" pipe, - like above floors, on a 1" feed to a copper cylinder when replacing for example. Anywhere else that a soldered connector is preferable I take plenty of time to emery the 1" pipe for a 28mm soldered connector to be used.
Brass fittings vary also. A conex fitting (& most decent brass fittings) tend to be bigger bore than cheap brass fittings & have bigger bore nuts, so are much better on an 1" pipe, or a pipe that has expanded slightly with frost damage.
Well I bought a couple of those fittings from plumb centre and they actually didn't slip. Was really difficult to even get the inch pipe into the inch end. Eventually I managed to force the 2 pipes apart to get the pipe in. Cost me 32 quid for 3 28mm slip couplers and 2 inch to 28mm couplers. Not cheap
Did you try a stnd 28 mm coupling ??
This is why i won't use plumb centre, local independants to me stock this and would have probably not cost too much more than a fiver.
Can get them in Graham's, I had a mare the other week trying to get hold of em
The moral of the story is buy a rothenburger expander and never have the problem again. I did and i don't booosh :)
Reply to 28mm metric to imperial... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
B
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
B
