Discuss 25mm Plastic Pipe T-off to 2x 20.9mm flexible hose in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a 25mm plastic (HDPE?, MDPE?....blue) pipe that comes into my shed and i'd like to run 2x flexible hose connectors off it. The internal diameter of the flexible hose connections looks to be about 20.9mm.
What would the pros recommend?
What’s the use for the hoses ?
And it’s mains correct ? What’s the use for the cold water ?
The plastic pipe runs from somewhere at the house and goes on a journey round the fairly large garden, it has a couple of stops (i think) before it gets to this shed. I'll be putting a stopcock inline to be able to shut it all off locally.
The flexible hoses then just go to some nicer taps, they have hot and cold input but will just be using the cold side.
The use for the water is just for domestic, cleaning etc
As for the flexiable hose are they plain end or like washing machine hoses ?
the flexible hose has a metal hexagonal metal fitting, about 20.9ish mm internal diameter, and the hose has a flexible metal mesh over it. Similar to the attached.
Reply to 25mm Plastic Pipe T-off to 2x 20.9mm flexible hose in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello everyone. New to the forum and looking for assistance / advice. I live in a rented house with a not very co-operative landlord. I have just...
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hi folks I need to fit a kitchen monobloc tap temporarily. A new sink unit will be going in soon so this will just be a stop gap. The current...
